Re: [cgal-discuss] Does CGAL::refine_Delaunay_mesh_2() support CGAL/Triangulation_euclidean_traits_xy_3.h?
- To:
- Subject: Re: [cgal-discuss] Does CGAL::refine_Delaunay_mesh_2() support CGAL/Triangulation_euclidean_traits_xy_3.h?
- Date: Thu, 2 Oct 2008 21:47:08 +0200
Hi, Refining the mesh means inserting the circumcenters of some facets. However, in the case of a terrain, the choice of a z-coordinate for the circumcenter is not clear. For this reason, refinement is not supported. See the documentation: The geometric traits class of the constrained Delaunay triangulation must be a model of DelaunayMeshTraits_2. The concept DelaunayMeshTraits_2 refines the concept ConformingDelaunayTriangulationTraits_2. It provides a construction objectConstruct_circumcenter_2. The class is a model of the concept DelaunayTriangulationTraits_2 except that it does not provide the type and constructors required to build the dual Voronoi diagram. If you still want to do that, you will have to provide a custom Construct_circumcenter_2 in a traits class derived from Triangulation_euclidean_traits_xy_3. -- Camille |
- [cgal-discuss] Does CGAL::refine_Delaunay_mesh_2() support CGAL/Triangulation_euclidean_traits_xy_3.h?, M. Hazegh, 10/02/2008
- Re: [cgal-discuss] Does CGAL::refine_Delaunay_mesh_2() support CGAL/Triangulation_euclidean_traits_xy_3.h?, Camille Wormser, 10/02/2008
- Re: [cgal-discuss] Does CGAL::refine_Delaunay_mesh_2() support CGAL/Triangulation_euclidean_traits_xy_3.h?, Laurent Rineau, 10/02/2008
