cgal-discuss - Re: [cgal-discuss] Facets_iterator
  • To:
  • Subject: Re: [cgal-discuss] Facets_iterator
  • Date: Sat, 4 Oct 2008 19:46:56 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:sender:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references:x-google-sender-auth; b=qe5Fu6KM41wJnuQfa7XIrBJ7CvxRq3iOfzTMiksnwr1S94DTKpqwplN91Qq9M604hW nRytpV1cXS4PemNUkruB9702kmjdmRcYysVrkri4RS6tmh7kf4QOaN6+t6oIDqCej8La x1+fHW0dXNG8s1g+BMOnPJ231HsrzZmLurRWM=
Did you bother looking at the manual?
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Mesh_2/Chapter_main.html
On Sat, Oct 4, 2008 at 6:13 PM, Dennis Endt
wrote:
> Thanks for you help, I foudn a solution with
> Triangulation T;
> for(Triangulation::Finite_facets_iterator it = T.finite_facets_begin();
> it != T.finite_facets_end(); it++)
> T.triangle(*it).vertex(i)
> Bu another Question. I integrated CGAL into my Project about to
> triangulate faces of different buildings.
> So I tried to use the 3D Delaunay Triangulation, but now I`ve the
> problem, that he also triangulates *in* my Object and not only the surfaces.
> For example I´ve an 3D Rectangle, what I have to do, to triangulate only
> the surfaces, so that I will have two triangles for each side and no
> triangles in my object?
> I tried also to adding the faces step by step about to triangulate them
> afterwards but it didn`t helped:
> Triangulation T;
> for(map<vector<QString>,QString>::iterator fListIter=fList.begin();
> fListIter != fList.end(); fListIter++)
> vector<Triangulation::Point> triFacePoints;
> vector<QString> fPoints = fListIter->first;
> for(vector<QString>::iterator fPointsIter = fPoints.begin();
> fPointsIter != fPoints.end(); fPointsIter++)
> map<QString,Triangulation::Point> ::iterator iter =
> pList.find(*fPointsIter);
> if(iter != pList.end())
> triFacePoints.push_back(iter->second);
> T.insert(triFacePoints.begin(),triFacePoints.end());
> This is very important to me. I hope someone could help me.
> Greets...
> M. Hazegh schrieb:
>> Your code will iterate through all faces of the triangulation. since
>> "it" is pointing to the current face, then
>> CGAL::to_double(it->vertex(i).x())
>> will return the x coordinate of the i'th vertex. For a triangle i = 0, 1, 2
>> If you want to iterate through all vertices of the triangulation, you
>> can use a Vertex_iterator. See the manual for more info.
>> On Sat, Oct 4, 2008 at 2:41 PM, Dennis Endt
>> wrote:
>>> Can anyone plz tell me how to read the the points of a facet?
>>> I tried to use this:
>>> But I didn`t find anything then to read the points with their coordinates.
>>> And what is the difference between finite and not finite faces/edges ...?
>>> I`m very thankful for every helpful information.
>>> You are currently subscribed to cgal-discuss.
>>> To unsubscribe or access the archives, go to
>>> https://lists-sop.inria.fr/wws/info/cgal-discuss
