- To:
- Subject: Re: [cgal-discuss] Alpha Shape 2D
- Date: Sun, 05 Oct 2008 18:55:44 +0200
Hi Juan Pablo,
Juan Pablo Carbajal wrote:
Andreas,
Yes, I have read the documentation.
The problem is - sorry for my newbiness - that I thought that with
those iterators I could do as follow
typedef CGAL::Alpha_shape_2<Delaunay> Alpha_shape;
Alpha_shape::Alpha_shape_vertices_iterator it =
A.alpha_shape_vertices_begin();
x = (*it).point().x();
y = (*it).point().y();
where A is an Alpha_shape_2 created from a list of Point_2.
This doesn't compile. The error says that it has no member "point".
You have to write "->point()" and not ".point()".
I admit that this is more our mistake than yours. The value_type of
the Alpha_shape_vertices_iterator; is Vertex_handle. I didn't find that
in the manual, but in the code.
typedef typename std::list< Vertex_handle >::iterator
So it should be changed or documented.
I was trying to read more on Vertex_handle but I cannot find
documentation and the header file is a little too much for my C++
level.
Admittedly the documentation of the Vertex is "hidden".
An Alpha Shape derives from Delaunay_triangulation_2, derives from
Triangulation_2
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.html#Cross_link_anchor_944
where you find
"The second parameter is the triangulation data structure, it has to be
instantiated
by a model of the concept TriangulationDataStructure_2"
When you click on TriangulationDataStructure_2 you find
"The concept can be seen as a container for the faces and vertices of the
triangulation.
The concept TriangulationDataStructure_2 includes two sub-concepts
TriangulationDataStructure_2::Vertex and
TriangulationDataStructure_2::Face."
and here we are
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TDS_2_ref/Concept_TriangulationDataStructure_2--Vertex.html#Cross_link_anchor_959
best regards,
andreas
Thanks again,
JPi
On Sun, Oct 5, 2008 at 2:07 PM, Andreas Fabri
Dear all,Hi Juan Pablo,
I am new to CGAL and I am trying to obtain the 2D alpha shape of a set
of points (in the plane, of course).
Everything is working ok but I just cannot figure out how to get the
list of vertices of the boundary of the alpha shape.
I have checked the discussions about alpha shapes boundaries in the
archive of the list but I could not find the solution there.
Is there something like
Alpha_shape_3::get_alpha_shape_vertices
for Alpha_shape_2?
Thanks
JPi
There is no iterator that allows you to follow the border, if that
is what you are looking for.
However, the alpha shape class provides iterators for enumerating
the vertices and edges
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Alpha_shapes_2_ref/Class_Alpha_shape_2.html#Cross_link_anchor_995
best regards,
andreas
- [cgal-discuss] Alpha Shape 2D, Juan Pablo Carbajal, 10/05/2008
- Re: [cgal-discuss] Alpha Shape 2D, Andreas Fabri, 10/05/2008
- Re: [cgal-discuss] Alpha Shape 2D, Juan Pablo Carbajal, 10/05/2008
- Re: [cgal-discuss] Alpha Shape 2D, Andreas Fabri, 10/06/2008
- Re: [cgal-discuss] Alpha Shape 2D, Daniel Duque Campayo, 10/06/2008
