cgal-discuss - [cgal-discuss] Need help to configure Geomview
  • To:
  • Subject: [cgal-discuss] Need help to configure Geomview
  • Date: Mon, 6 Oct 2008 07:58:56 -0700 (PDT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Mailer:Date:From:Subject:To:MIME-Version:Content-Type:Message-ID; b=fZ4V+/THotEQUzTpDz+QwcCXk3azqFwtThPkooVmlMQ/yzgwHdJlzk0FxEaDsZ1/yN/0O+84OUyKgbEHqIh1AM5XdubFDX9AerWVMMnKnPohm0RkIWD8UT99MYFXYs2h/tEtbgvTgu23+E6rFFr7Wv/KAYy8P5V3BvVy21+Z/MQ=;
Hello Friends,
As I need to view the .off object. I tried to configure Geomview on my PC.
I work on Visual C++ 2005 on Windows XP. So that I first installed cygwin and than geomview. I followed the procedure shown on http://personal.ee.surrey.ac.uk/Personal/L.Wood/software/SaVi/building-under-Windows/
But it dint work for me. The error on X-window is like...
    Samay@home-pc /cygdrive/c/geomview-1.9.4
    $ ./reconf
    + autoreconf -i
    ./reconf: line 3: autoreconf: command not found
Than I tried downloading autoconf, automake and libtool from http://sources.redhat.com/autobook/.
I also did run make command going in direcotory of these all packages. Than I copied commands like autoconf, autoreconf, automake, libtool to directory C:/Geomview-1.9.4/.
Than I tried again ./reconf but the same error as above. I am sure that autoreconf command is there.
I dont know how to get out of thise chaos. It seems I am missing something.
If anybody have solution of this chaos or some good material how to use Geomview on Windows XP using Visual Studio than please forward them.
Thanks in advance.
Greetings,
Samay
