cgal-discuss - Re: [cgal-discuss] Delaunay::Finite_edges_iterator give some rare
  • To:
  • Subject: Re: [cgal-discuss] Delaunay::Finite_edges_iterator give some rare
  • Date: Wed, 8 Oct 2008 11:42:41 -0300
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:in-reply-to:mime-version :content-type:content-transfer-encoding:content-disposition :references; b=DCFuq6FiNLvhDlACOO/YGW6TWp54tB7KyXznzGeqwloH+oYw/CjPJ14sjy1187RZWb RTs844cKFtJZRlOi86uXlsgcI5P2QHpJBzx9khtKM2DqYbG3qgRYbd0OtxOcIyHuYnX7 VHY5MriyclbrnD+QGN0HxH7POtNVVXHx83mvo=
Thanks a lot. It works.
2008/10/8 Olivier Devillers
> pam a écrit :
>> Hi all!
>> I'm working with delaunay 3D and I was able to view cells ans faces
>> but when I try to go trougth the edge I get some rare points that are
>> not part of my points.
>> Here is my code. Any idea of what is wrong?
>> Delaunay::Finite_edges_iterator edge;
>> Point pt0;
>> Point pt1;
>> for(edge=T.finite_edges_begin(); edge != T.finite_edges_end();edge++)
>> std::cout<<" Edges "<<j<<std::endl;
>> pt0=edge->first->vertex(Delaunay::cw(edge->second))->point();
>> pt1=edge->first->vertex(Delaunay::ccw(edge->second))->point();
>> std::cout<<pt0<<std::endl;
>> std::cout<<pt1<<std::endl;
>> j++;
>> Thanks in advance
>> Pamela
> from
> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/TriangulationDS_3_ref/Concept_TriangulationDataStructure_3.html#Cross_link_anchor_986
> typedef Triple<Cell_handle, int, int>
> Edge; (c,i,j) is the edge of cell c whose vertices indices are i and
> j. (See Section 28.1.)
> thus it seems that you should use
> pt0=edge->first->vertex(edge->second)->point();
> pt1=edge->first->vertex(edge->third)->point();
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
