- To:
- Subject: [cgal-discuss] Converting data under one kernel to another
- Date: Fri, 10 Oct 2008 01:05:44 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=uUP3HHru7nW39Y5XqlMkOSF3mQkmHam+nLhfGSmrlECfr8M07l9XJFgvJCiZlYCSE3 QzxDLvDyS54mfQf4RwEJy0nBRsqE6n3HFc/0/nGTaKNJD+HRNluYtGz5ihiqz1gU3RrK GFl9Qmtyl0ANR3j5ijbaj71WnfX6xpPkOtL84=
Hi All,
I have a general question about converting data from one class to another.
E.g. How do I convert a segment from one 'Traits' to another.
typedef CGAL :: Exact_predicates_inexact_constructions_kernel K;
typedef CGAL :: Segment_Delaunay_graph_traits_2<K> SDGT2;
typedef CGAL :: Segment_Delaunay_graph_2<SDGT2> SDG2;
typedef CGAL::Arr_segment_traits_2<K> Traits_2;
SDG2::Site_2 site;
Traits_2::Segment_2 seg;
How do I convert site into seg???
Currently I am going all the way down up to the x & y coordinates of the endpoints and build the segment from there. Like,
seg = Traits_2::Curve_2(Traits_2::Point_2(site.source().hx(), site.source().hy()), Traits_2::Point_2(site.target().hx(), site.target().hy()));
But then I lose the precision, probably since the x & y coordinates get approximated and the site and seg refer to two different segments.
I face the same problem whenever I want to convert points from one kernel to another like Exact_predicates_inexact_constructions_kernel::Point_2 to Exact_circular_kernel_2::Point_2. I have to go all the way down upto the x,y coordinate level. And then you are bound to lose the precision then, isnt it? Am I missing something here?
Is there any better or rather proper way to do it?
Thanks & Regards,
Amit Pendharkar
SDG2::Site_2 site;
Thanks & Regards,
Amit Pendharkar
- [cgal-discuss] Converting data under one kernel to another, Amit Pendharkar, 10/10/2008
- Re: [cgal-discuss] Converting data under one kernel to another, Monique Teillaud, 10/10/2008
