- To:
- Subject: Re: [cgal-discuss] 3D meshes with minimal area
- Date: Sat, 11 Oct 2008 19:41:10 +0200
- Organization: INRIA
hi Daniel,
about link with area I would advise you to read some work of Ramsay Dyer
(Delaunay mesh construction, etc.) as well as some work of kai Hormann, see http://www2.in.tu-clausthal.de/~hormann/pub_chrono.html "optimizing 3d triangulations using discrete curvature analysis".
Pierre
a écrit :
Hello everyone,
My current research leads me to computing a 3D mesh triangulating a (given)
set
of points. It is important that this mesh has a minimal area; I somehow
assumed
this would be taken care of by using Delaunay triangulations, but I am not so
sure about this now. I'd greatly appreciate any help regarding the connection
between 3D Delaunay meshes and area.
More technically:
I have read the documentation about 3D surface mesh generation. Not quite
what I
wanted, since my points are given (I have no implicit function), but still
interesting. The idea centers about the mesh having empty surface Delaunay
balls. I quote: "A surface Delaunay ball is a ball circumscribing a mesh facet
and centered on the surface." Since my surfaces are nearly planar I was making
progress by using 2D Delaunay terrains, hoping that the resulting mesh would
still have empty balls.
Anyway, I am now doubting there is a strong connection between the Delaunay
condition of empty balls/circles and minimal area. Perhaps I'll have to write
my
own code for triangulating terrains in such a way that the area is kept
minimal?
Best,
Daniel
Mensaje enviado mediante una herramienta Webmail integrada en *El Rincon*:
------------->>>>>>>> https://rincon.uam.es <<<<<<<<--------------
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
- [cgal-discuss] 3D meshes with minimal area, daniel . duque, 10/11/2008
- Re: [cgal-discuss] 3D meshes with minimal area, Pierre Alliez, 10/11/2008
