- To:
- Subject: Re: [cgal-discuss] which are function to read .off Element?
- Date: Wed, 22 Oct 2008 17:04:13 +0200
Hi Samay,
especially for beginners it is helpful to have a look at the manual.
It is organized in chapters for data structure and you should
lok here
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_12.3.1
and for your specific question go to
12.3.2 Example with Geometry in Vertices
Besides the user manual with examples there is also the Reference
manual with a page per class listing and explaining member functions.
Follow the link at the bottom,
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Polyhedron_ref/Chapter_intro.html
or click on "Reference Manual" for the chapter
http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/contents.html#part_VI
hope this helps,
andreas
Samay Kumar wrote:
Hello Friends,
I have successfully able to read .off file using Polyhedron_3<Kernel> but I dont to how to access list of vertex and faces.
Actually I am really a beginner in C++ as well CGAL so that facing a little bit lack of help how to use functions of CGAL. Kindly provide me hint. I could have able to access size of vertex, edges and faces using P.size_of_vertices() but could not find function to access list of vertex cordinates.
Kindly give hint how to access...
1. list of vertex co-ordinates
2. list of indexes of vertex per face
3. how to access particular vertex.
Thanks a lot for any help in advance.
Greetings,
Samay
- [cgal-discuss] which are function to read .off Element?, Samay Kumar, 10/22/2008
- Re: [cgal-discuss] which are function to read .off Element?, Andreas Fabri, 10/22/2008
