cgal-discuss - Re: [cgal-discuss] Subtending Triangles
  • To:
  • Subject: Re: [cgal-discuss] Subtending Triangles
  • Date: Wed, 22 Oct 2008 17:31:17 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=googlemail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject:references :in-reply-to:content-type:content-transfer-encoding; b=t6QMVJFX/g0ofJiBCZ+G7DtUjifWPVdR8wFJn+1IKda4ljz6D7ReSOh+0rM3vdFxHF SalnadWNUo3xXZLOTKx1c5g9HdDR1cM77Hm8GNgwfur6VJ1eLjRJOlXs+z9eYMCJCscB 5q3k8d/XpUUwEMAsRTSulLT0IHsPVqurtu9r0=
Monique Teillaud schrieb:
> Samuel Hornus wrote:
>> Dennis Endt
>> wrote:
>>> I just mean a function to prove, if two triangles have a positive or
>>> negative intersection. I they cut each other and so on...
>> It seems such a function does not exist, as you can see on this
>> page of the manual (rings a bell ?)
>> http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Kernel_23_ref/Function_intersection.html
>> You may make do with the intersection described in the above web page,
>> though.
> I guess the link to do_intersect given by Olivier is even more
> appropriate
>> As for the orientation you want to give to an intersection, I must admit
>> I have never come accross such a concept, and I present to you my most
>> sincere apologies for not understanding this.
> shall we present global apologies? ;)
> Monique Teillaud
Thanks a lot for your Help :)
Best
Dennis
