cgal-discuss - RE: [cgal-discuss] [CGAL-Discuss] drgon.off is not opened with CGAL lib
  • To: <>
  • Cc: <>
  • Subject: RE: [cgal-discuss] [CGAL-Discuss] drgon.off is not opened with CGAL lib
  • Date: Sat, 25 Oct 2008 10:50:44 -0400
  • Organization: Purdue
Hi Pierre,
Thank you very much, now it works, can you teach me how you fixed it because
I have more models that are not opened? I know the number of vertices was
wrong, but how did you fix? Did you use a text editor to find the correct
number of vertices on the .off file?
Samuel
-----Original Message-----
[mailto:]
Sent: Saturday, October 25, 2008 2:53 AM
To:
Subject: Re: [cgal-discuss] [CGAL-Discuss] drgon.off is not opened with CGAL
lib
hi Samuel,
here is a fixed version.
samuel kim a écrit :
> Hello,
> I should work with dragon.off file for my research, however, it is not
> opened with CGAL lib. When I tested bunny.off from Stanford 3D model
> repository, it was fine. Anybody knows the reason? The attached is the
> model that I am working with CGAL 3.3.1. Thank you.
> Samuel
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
