- To:
- Subject: Re: [cgal-discuss] halfedges
- Date: Sat, 25 Oct 2008 15:24:07 -0300
Hi!
Nobody has an idea how to obtain the direction of infinite halfedges?
thanks hj
Hanjoerg Seybold writes:
Hello!
I am making calculations with voronoi diagrams. For my application i have to intersect the unbounded edges/halfedges with a boundary given by a polygon or a segment or line. After studying the manual and i am a bit confused about the halfedge structure.
1. it is said that "Halfedges are oriented edges", but i cannot find a
method how to access the orientation.
2. It is possibe to check if a halfedge IS a segment or ray. h.is_ray(),
but if the halfedge IS a ray, how can i access its features (direction,
etc.)?
3. My Problem is that i iterate through the halfedges and i want to know if
a infinite halfedge intersects a polygon. For this i wanted to construct
a line ray etc out of the halfedge, but i dont know how to obtain the
direction in the case that the halfedge has only source OR target.
Any help would be welcome
hansjoerg
- [cgal-discuss] halfedges, Hanjoerg Seybold, 10/21/2008
- Re: [cgal-discuss] halfedges, Hanjoerg Seybold, 10/25/2008
- Re: [cgal-discuss] halfedges, Olivier Devillers, 10/27/2008
- Re: [cgal-discuss] halfedges, Hanjoerg Seybold, 10/28/2008
