- To:
- Subject: Re: [cgal-discuss] unepxected facet normal value
- Date: Sat, 25 Oct 2008 22:59:52 +0200
- Organization: INRIA
hi Samuel,
you can derive your own enriched polyhedron with normals per vertex and facet, see example below. I have added a member function "compute_normals()"
#include <CGAL/Cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/HalfedgeDS_default.h>
#include <CGAL/gl.h>
namespace CGAL
template <class Refs, class T, class P, class Norm>
class Textured_facet : public CGAL::HalfedgeDS_face_base<Refs, T>
// normal
Norm m_normal;
public:
// life cycle
// no constructors to repeat, since only
// default constructor mandatory
Textured_facet()
// normal
typedef Norm Normal_3;
Normal_3& normal() { return m_normal; }
const Normal_3& normal() const { return m_normal; }
template <class Refs, class Tprev, class Tvertex, class Tface, class Norm>
class Textured_halfedge : public CGAL::HalfedgeDS_halfedge_base<Refs,Tprev,Tvertex,Tface>
public:
// life cycle
Textured_halfedge()
class Textured_vertex : public CGAL::HalfedgeDS_vertex_base<Refs, T, P>
// normal
Norm m_normal;
public:
// life cycle
Textured_vertex() {}
// repeat mandatory constructors
Textured_vertex(const P& pt)
: CGAL::HalfedgeDS_vertex_base<Refs, T, P>(pt)
// normal
struct Textured_items : public CGAL::Polyhedron_items_3
// wrap vertex
template<class Refs, class Traits> struct Vertex_wrapper
typedef typename Traits::Point_3 Point;
typedef typename Traits::Vector_3 Normal;
typedef Textured_vertex<Refs,
CGAL::Tag_true,
Point,
Normal> Vertex;
// wrap face
template<class Refs, class Traits> struct Face_wrapper
typedef Textured_facet<Refs,
CGAL::Tag_true,
Point,
Normal> Face;
// wrap halfedge
template<class Refs, class Traits> struct Halfedge_wrapper
typedef Textured_halfedge<Refs,
CGAL::Tag_true,
CGAL::Tag_true,
CGAL::Tag_true,
Normal> Halfedge;
// compute facet normal
struct Facet_normal // (functor)
template<class Facet> void operator()(Facet& f)
typename Facet::Normal_3 sum = CGAL::NULL_VECTOR;
typename Facet::Halfedge_around_facet_circulator h = f.facet_begin();
do
typename Facet::Normal_3 normal = CGAL::cross_product(h->next()->vertex()->point() - h->vertex()->point(), h->next()->next()->vertex()->point() - h->next()->vertex()->point());
double sqnorm = normal * normal;
if (sqnorm != 0)
normal = normal / (float)std::sqrt(sqnorm);
sum = sum + normal;
} while (++h != f.facet_begin());
float sqnorm = sum * sum;
if (sqnorm != 0.0)
f.normal() = sum / std::sqrt(sqnorm);
else
f.normal() = CGAL::NULL_VECTOR;
// compute vertex normal
struct Vertex_normal // (functor)
template<class Vertex> void operator()(Vertex& v)
typename Vertex::Normal_3 normal = CGAL::NULL_VECTOR;
typename Vertex::Halfedge_around_vertex_const_circulator pHalfedge =
v.vertex_begin();
typename Vertex::Halfedge_around_vertex_const_circulator begin =
pHalfedge;
CGAL_For_all(pHalfedge,begin)
if(!pHalfedge->is_border())
normal = normal + pHalfedge->facet()->normal();
float sqnorm = normal * normal;
if (sqnorm != 0.0f)
v.normal() = normal / (float)std::sqrt(sqnorm);
else
v.normal() = CGAL::NULL_VECTOR;
template <class Kernel, class Items>
class Textured_polyhedron : public CGAL::Polyhedron_3<Kernel,Items>
public :
typedef typename Kernel::FT FT;
typedef typename Kernel::Point_3 Point;
typedef typename Kernel::Vector_3 Vector;
typedef typename CGAL::Polyhedron_3<Kernel,Items> Base;
typedef typename CGAL::Polyhedron_3<Kernel,CGAL::Polyhedron_items_3> Basic_polyhedron;
typedef typename Base::Vertex_handle Vertex_handle;
typedef typename Base::Vertex_iterator Vertex_iterator;
typedef typename Base::Halfedge_handle Halfedge_handle;
typedef typename Base::Halfedge_iterator Halfedge_iterator;
typedef typename Base::Halfedge_around_facet_circulator Halfedge_around_facet_circulator;
typedef typename Base::Halfedge_around_vertex_circulator Halfedge_around_vertex_circulator;
typedef typename Base::Edge_iterator Edge_iterator;
typedef typename Base::Facet Facet;
typedef typename Base::Facet_iterator Facet_iterator;
typedef typename Base::Facet_handle Facet_handle;
public :
// life cycle
Textured_polyhedron()
virtual ~Textured_polyhedron()
// normals (per facet, then per vertex)
void compute_normals_per_facet()
std::for_each(this->facets_begin(),this->facets_end(),Facet_normal());
void compute_normals_per_vertex()
std::for_each(this->vertices_begin(),this->vertices_end(),Vertex_normal());
void compute_normals()
compute_normals_per_facet();
compute_normals_per_vertex();
}; // end class Textured_polyhedron
}; // end namespace CGAL
#endif // _TEXTURED_MESH_
Andreas Fabri a écrit :
Hi Samuel,
Note that the Polyhedron class doesn't compute the plane equations,
but only provides storage for them.
See http://www.cgal.org/Manual/3.3/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Subsection_12.3.4
Best regards,
andreas
samuel kim wrote:
Hell all,
I want to know how to remove this unexpected case. When get a facet normal
vector from Halfedge, occasionally, some normal vectors returns -1.#IND00.
Is this meaning that no nomal vector is on the facet? If so, what is the
condition to avoid the facet that has no normal vector? Thank you.
Example) Vector Norm = pHalfEdge->facet()->normal();
Norm[0] = -1.#IND00
Norm[1] = -1.#IND00
Norm[2] = -1.#IND00
Samuel
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
- [cgal-discuss] unepxected facet normal value, samuel kim, 10/25/2008
- Re: [cgal-discuss] unepxected facet normal value, Andreas Fabri, 10/25/2008
- Re: [cgal-discuss] unepxected facet normal value, Pierre Alliez, 10/25/2008
