- To:
- Subject: Re: [cgal-discuss] help with CGAL conceptual
- Date: Mon, 27 Oct 2008 23:07:37 +0100
Edges aren't really stored in Triangulation data structure still can be
accessed threw handlers, iterators and circulators.
Still have a question: How do I create/get edge_handler from a facet?
Here is what the Triangulation_data_structure_3 manual says:
typedef Triple<Cell_handle, int, int> Edge;
(c,i,j) is the edge of cell c whose vertices indices are i and j. (See Section 28.1.)
typedef std::pair<Cell_handle, int> Facet;
(c,i) is the facet of c opposite to the vertex of index i. (See Section 28.1.)
In your code, you would access the Cell_handle and the index from the Facet_iterator facet by doing
Cell_handle c = facet->first;
int index = facet->second;
Camille
- [cgal-discuss] help with CGAL conceptual, Nizar Khalifa Sallem, 10/27/2008
- Re: [cgal-discuss] help with CGAL conceptual, Bernd Gaertner, 10/27/2008
- Re: [cgal-discuss] help with CGAL conceptual, Nizar Khalifa Sallem, 10/27/2008
- Re: [cgal-discuss] help with CGAL conceptual, Camille Wormser, 10/27/2008
- Re: [cgal-discuss] help with CGAL conceptual, nksallem, 10/27/2008
