- To:
- Subject: Re: [cgal-discuss] How to repair .off file?
- Date: Wed, 29 Oct 2008 15:05:18 +0100
On Wednesday 29 October 2008 14:51:16 Samay Kumar wrote:
> Hello Friends,
> I have some .off file which is not being viewed by GeomView visualizer.
When you open bottle.off with Emacs, you see that the file is opened using
the
coding system "DOS". Geomview on linux does not link windows end of lines.
The solution is just to run dos2unix on them.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] How to repair .off file?, Samay Kumar, 10/29/2008
- Re: [cgal-discuss] How to repair .off file?, Laurent Rineau, 10/29/2008
- Re: [cgal-discuss] How to repair .off file?, Nizar Khalifa Sallem, 10/29/2008
- <Possible follow-up(s)>
- Re: [cgal-discuss] How to repair .off file?, Samay Kumar, 10/29/2008
