- To:
- Subject: Re: [cgal-discuss] Why straight skeleton algorithm in CGAL is so
- Date: Wed, 29 Oct 2008 18:00:43 -0300
jiatao83 wrote:
Dear All:
The code followed:
typedef CGAL::Exact_predicates_inexact_constructions_kernel Kernel;
typedef Kernel::Point_2 Point_2;
typedef CGAL::Straight_skeleton_2<Kernel> Ss;
typedef Ss::Halfedge_iterator Halfedge_iterator;
typedef Ss::Halfedge_handle Halfedge_handle;
typedef Ss::Vertex_handle Vertex_handle;
typedef CGAL::Straight_skeleton_builder_traits_2<Kernel> SsBuilderTraits;
typedef CGAL::Straight_skeleton_builder_2<SsBuilderTraits,Ss> SsBuilder;
SsBuilder ssb;
for(int i=0;i++;i<27)
/* According to the boundary to generate the pts */
Point_2* pts=new Point_2[numPointsInPart];
ssb.enter_contour(pts,pts+numPointsInPart-1);
ss=ssb.construct_skeleton();
The program so time-consuming that it needs about 27 hours
That is incredibly slower than it ought to be. The worst case for a
polygon this size I've seen is a few mintues.
Can you send, directly to me private email a text file with the
coordinates of your boundaries, each boundary starting with a line
indicating the number of vertices, and details on your platform,
compiler and most importantly flags and defines?
TIA
Fernando Cacciola
- [cgal-discuss] Why straight skeleton algorithm in CGAL is so time-consuming, jiatao83, 10/26/2008
- Re: [cgal-discuss] Why straight skeleton algorithm in CGAL is so, Fernando Cacciola, 10/29/2008
