cgal-discuss - Re: [cgal-discuss] Problem using CGAL with OpenCV under Windows and
  • To:
  • Subject: Re: [cgal-discuss] Problem using CGAL with OpenCV under Windows and
  • Date: Fri, 21 Nov 2008 15:57:40 +0000 (GMT)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.es; h=X-YMail-OSG:Received:X-Mailer:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type:Content-Transfer-Encoding:Message-ID; b=TiK6XJl+d+Dvq/ihC2NG2/wlOaSZZ5sHaB1Eol5haptiq2IZTexv2vpRzGTClqEDfS2vwqdq6rfNbSyeuc/wvgs1SQd5TvDib3P3d3APHhtMca0gtHqCVZnDumMpdfcfocgTley2qAgfyllxili0Iik+o1NxciyNuIPeTTv/yZo=;
Thank you. I have reordered the include statatements so the CGAL ones come
first and the problem is fixed.
--- El vie, 21/11/08, Sylvain Pion
escribió:
> De: Sylvain Pion
> Asunto: Re: [cgal-discuss] Problem using CGAL with OpenCV under Windows and
> Para:
> Fecha: viernes, 21 noviembre, 2008 4:27
> wrote:
> > Good afternoon,
> > I am trying the CGAL libraries to compute the
> Medial-Axis of a contour. I get
> > that contour using OpenCV, and I have to use OpenCV.
> This is part of my tesis
> > research work so I am really interested in completing
> my tests as soon as
> > possible.
> > Unfortunately, I think that there is some kind of
> incompatibility between
> > OpenCV and CGAL and I can not figure out how to solve
> it.
> > All the errors are related to the Assertions.h file:
> > Example:
> > \include\cgal\assertions.h(34) : error
> C2143: syntax error : missing '}' before
> > 'goto'
> This line is:
> enum Failure_behaviour { ABORT, EXIT, EXIT_WITH_SUCCESS,
> CONTINUE,
> THROW_EXCEPTION };
> What most probably happens is that OpenCV (or other
> software you use), defines
> one of these names as a macro, which clashes with
> CGAL's enum.
> One probable fix is to include CGAL's header first,
> before the other problematic
> headers that defines the macro in question.
> (and maybe suggest that OpenCV does not define macros with
> such general names:
> good practice for libraries is to have macros with prefixes
> to avoid clashes)
> -- Sylvain Pion
> INRIA Sophia-Antipolis
> Geometrica Project-Team
> CGAL, http://cgal.org/
