- To:
- Subject: [cgal-discuss] method to check non-manifold?
- Date: Tue, 25 Nov 2008 21:04:17 -0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type :content-transfer-encoding:content-disposition; b=qKgIdR2DA6grMXWnd6yuCvsmRzdWEPNCcg4GZxml9S6VazoeYd0e+HpVig5zTcZ+aT E3Iryql7jO+eDqQaV/ef+HLkJmmQmZdSP0FbOOP+0yJ+5efbhE4bC7oy7auF6L+LrhvC 3NBxbBxguqYtZ02/lw2PQK6GEkT6pfJT3jp+o=
hello list,
in my program, non-manifold facets (polyhedron <half-edge> ) could
lead to problems. i want to remove or at least detect non-manifold
facets. but how can i do this?
in my program, it seems that the non-manifold problem is caused by two
facets share a common point that doesn't locate at the facets' border.
one way of solving the non-manifold problem is checking all the facets
of the problematic point, see if they are connected. however under the
non-manifold situation, the neighborhood information cannot be gotten
by using the point's circulator.
is there any ready made method to check non-manifold?
thank you.
- [cgal-discuss] method to check non-manifold?, Shi Yan, 11/26/2008
