- To:
- Subject: [cgal-discuss] Can CGAL do meshing job from a point cloud ?
- Date: Fri, 28 Nov 2008 01:04:03 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=KJ3DkkvmejyfmDCWH+STk+ZPrvbHqmMTs8JkEfjGdj7PraHva/dTBipq6Ni5N4LgEZ GfgYId0n77RmDvUJJWiWuB3KGUrSLK3cqkwafa4h9ZQwINJyGlC3MhpvGFvKxgw5n+Xw VhuztnY6+xK9BiXUkOrn4Mqkg80armHh8WJNQ=
Dear all,
I am tring to use the CGAL on the meshing job.
I take the laser range finder to scan the campus building, then get a point cloud.
And, I use the CGAL/Delaunay_triangulation_3 to link up all the points into triangles, but how do I make some criterion to restrict the linking distance between two points ? ( because there are some noises from the laser scanner )
Or should I use the surface meshing method refered in CGAL manual Ch35 ? But I can't figure out how to do that from a point cloud.
Do anyone have good idea ?
Thank you,
Allen
- [cgal-discuss] Can CGAL do meshing job from a point cloud ?, Alen Chu, 11/27/2008
