- To: cgal-discuss <>
- Subject: [cgal-discuss] Convex Volume in Higher Dimensions
- Date: Fri, 28 Nov 2008 17:05:32 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=sWlsrW+KOMhoMJRhkilCzy5cXY1AIh5rJTWwgmwkP9mDfAim9QzVySOh5J9zUofkid 3JkNC0FWh0zEveNaOw/620OxmXsBZA3S7h76zI2PvndnhPAGpKu/AbjDK3sR5+ItpSgs Ogusrxfi9v1B/x9t6S0xodPnds6DYZsfMnMbA=
Hello,
1). I am not quite sure if CGAL has module which can calculate the volume of Convex Polytope in extremely
high dimension. ( Typically I want to calculate in dimensions > 1000). If it exist, please let me know.
2). In order to experiment with Kannan's paper for calculating volumes, I need one predicate in higher
dimension i.e. point inside Polytope. Is there any robust module in CGAL for this task ?
Thanks.
csv
- [cgal-discuss] Convex Volume in Higher Dimensions, Chaman Singh Verma, 11/28/2008
- Re: [cgal-discuss] Convex Volume in Higher Dimensions, Bernd Gaertner, 11/28/2008
