- To: cgal-discuss <>
- Subject: [cgal-discuss] Why this simple code hang my machine ?
- Date: Sat, 29 Nov 2008 14:01:00 +0530
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:to:subject:mime-version:content-type; b=K6Y1V5vsWIuqqqgCMjdVsdvRzOehWt+MBZSUK6AJvqKAZZ91TdsHbZI4B5NAN8CgJj IgjzaMu/bAUGdBPslWbTzZ8QXoxbKMR0NlL5ieR8OXz1ckgHPNFIANFdRaKF2X+/CUC4 bKZB0ALSBpBPyM7b9bQjD3k+U+L3H6DD6oO0k=
Hello,
I have modify the example code of Convex3D and it just keep on running till my machine hangs ?
Thanks.
csv
#include <CGAL/Homogeneous.h> #include <CGAL/Cartesian.h> #include <CGAL/point_generators_3.h> #include <CGAL/copy_n.h> #include <CGAL/Convex_hull_traits_3.h> #include <CGAL/convex_hull_3.h> #include <vector> typedef CGAL::Cartesian<double> K; typedef CGAL::Convex_hull_traits_3<K> Traits; typedef Traits::Polyhedron_3 Polyhedron_3; typedef K::Segment_3 Segment_3; typedef K::Point_3 Point_3; typedef CGAL::Creator_uniform_3<double, Point_3> PointCreator; int main() { CGAL::Random_points_in_sphere_3<Point_3, PointCreator> gen(100.0); std::vector<Point_3> points; CGAL::copy_n( gen, 250, std::back_inserter(points) ); CGAL::Object ch_object; CGAL::convex_hull_3(points.begin(), points.end(), ch_object); Segment_3 segment; Polyhedron_3 polyhedron; if ( CGAL::assign(segment, ch_object) ) std::cout << "convex hull is a segment " << std::endl; else if ( CGAL::assign (polyhedron, ch_object) ) std::cout << "convex hull is a polyhedron " << std::endl; else std::cout << "convex hull error!" << std::endl; return 0; }
- [cgal-discuss] Why this simple code hang my machine ?, Chaman Singh Verma, 11/29/2008
- Re: [cgal-discuss] Why this simple code hang my machine ?, Sylvain Pion, 11/29/2008
- Re: [cgal-discuss] Why this simple code hang my machine ?, Chaman Singh Verma, 11/29/2008
