- To:
- Subject: [cgal-discuss] Vertices of Convex_hull_d
- Date: Tue, 2 Dec 2008 10:28:10 +0100 (CET)
Hi,
I'd like to find vertices of convex hull of points in arbitrary dimension
using
Convex_hull_d. I just tried the 9 points of square centered at the origin.
Obviously, I should get 4 points, but I'm getting 8. Any thought?
Here goes the code that I tried.
Thanks,
#include <iostream>
#include <vector>
#include <CGAL/Cartesian.h>
#include <CGAL/Convex_hull_d.h>
#include <CGAL/Cartesian_d.h>
using namespace std;
using namespace CGAL;
int main()
Convex_hull_d< Cartesian_d<double> > A(2);
vector< vector<int> > V;
vector<int> vi(DIM);
vi[0]=-1; vi[1]=1; V.push_back(vi);
vi[0]=0; vi[1]=1; V.push_back(vi);
vi[0]=1; vi[1]=1; V.push_back(vi);
vi[0]=-1; vi[1]=0; V.push_back(vi);
vi[0]=0; vi[1]=0; V.push_back(vi);
vi[0]=1; vi[1]=0; V.push_back(vi);
vi[0]=-1; vi[1]=-1; V.push_back(vi);
vi[0]=0; vi[1]=-1; V.push_back(vi);
vi[0]=1; vi[1]=-1; V.push_back(vi);
for( vector< vector<int> >::iterator it=V.begin(); it!=V.end(); it++
Point_d< Cartesian_d<double> >
pot(DIM,(*it).begin(),(*it).end());
A.insert(pot);
for( Convex_hull_d< Cartesian_d<double> >::Hull_vertex_iterator
it=A.hull_vertices_begin() ; it!=A.hull_vertices_end(); it++ )
cout << A.associated_point(it) << endl;
return 0;
- [cgal-discuss] Vertices of Convex_hull_d, hkim, 12/02/2008
- Re: [cgal-discuss] Vertices of Convex_hull_d, Bernd Gaertner, 12/02/2008
- Re: Re: [cgal-discuss] Vertices of Convex_hull_d, hkim, 12/02/2008
