cgal-discuss - Re: [cgal-discuss] Delaunay Triangulation to Boost Graph
  • To:
  • Subject: Re: [cgal-discuss] Delaunay Triangulation to Boost Graph
  • Date: Wed, 03 Dec 2008 16:13:55 +0100
Qu Yang wrote:
Hi all,
I've been trying to convert a delaunay triangulation (DT) to a boost graph.
I want to some operation, such as removing edges in the obtained graph.
The provided example that uses a filtered graph only return a reference to DT.
How can I get a deep copy of the filered graph?
Yang
Hi Yang,
Sorry for the late reply. The idea of the boost::filtered_graph
is just to not physically remove vertices and edges, but to have
a function object which decides if one iterates over vertices and
edges or not.
If you really want a new graph, you should maybe have a look at
http://www.boost.org/doc/libs/1_37_0/libs/graph/doc/copy_graph.html
best regards,
andreas
