- To:
- Subject: Re: [cgal-discuss] Cannot read Polyhedron from OFF .
- Date: Thu, 4 Dec 2008 18:41:12 +0100
On Thursday 04 December 2008 17:42:07
wrote:
> Hi,
> I am a newbie to CGAL. I was writing a code to access OFF files. I am not
> able to access the properties of mesh. Could some one please point out
> where I am making the mistake.
> #include <CGAL/Simple_cartesian.h>
> #include <CGAL/Polyhedron_3.h>
> #include <CGAL/IO/Polyhedron_iostream.h>
> #include <iostream>
> #include <istream>
> #include <fstream>
> typedef CGAL::Simple_cartesian<double> Kernel;
> typedef CGAL::Polyhedron_3<Kernel> Polyhedron;
> int main() {
> std::ifstream stream("test.off");
> Polyhedron P;
> stream >> P;
> std::cout << "\n "<<P.size_of_vertices();
> return 0;
The correct code is that one:
int main() {
if(!stream} {
std::cerr << "Cannot open file!\n";
return 1;
Polyhedron P;
stream >> P;
if(!stream} {
std::cerr << "test.off is not a polyhedron\n";
return 1;
return 0;
That is: you need to test the good() bits of the stream *after* the attempt
to
read a polyhedron from it.
Most probably you OFF file does not correspond to a manifold *and oriented*
mesh (with optional boundaries). You need to orient your off before trying to
read it to a polyhedron.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] Cannot read Polyhedron from OFF ., nikhilnavkar, 12/04/2008
- Re: [cgal-discuss] Cannot read Polyhedron from OFF ., Yang Qu, 12/04/2008
- Re: [cgal-discuss] Cannot read Polyhedron from OFF ., Laurent Rineau, 12/04/2008
