- To:
- Subject: Re: [cgal-discuss] introspect-qt
- Date: Thu, 18 Dec 2008 14:10:35 +0100
Hello,
sorry for the inconvenience but this visu tool was only experimental and is not longer maintained.
You may still want to try to use the output file of the example program to generate a visualization with Goemview or any other soft of your choice.
Best,
Marc
On 16 , Dec , 2008, at 16:33 , <> <> wrote:
Hello,
I'm trying to view the output of the Jet_fitting_3 example, but I can't seem
to find the introspect-qt program which the tutorial suggests to use for
viewing its output. It doesn't seem to be in the example or demo directories,
and a Google search yields only the CGAL tutorial page, and no link to the
code.
Thanks,
Rob
- [cgal-discuss] introspect-qt, rob.patro, 12/16/2008
- Re: [cgal-discuss] introspect-qt, Marc Pouget, 12/18/2008
