- To:
- Subject: [cgal-discuss] Boolean operations on triangle surfaces
- Date: Sat, 27 Dec 2008 11:17:51 +0100 (CET)
I'm new to CGAL. I currently use OpenCascade to do Boolean operations but I've
found it is too slow for my needs. I've read that the CGAL Nef_polyhedron_3
has
optimizations for these operations. I'd be grateful if you could tell me if
CGAL can compute the following.
I have two closed solids bounded by triangle meshes, call them A and B.
First, I'd like to cut one with the other, i.e. compute C=A-B. The result C
should be a closed polyhedron, and I'd like to convert it to a triangle mesh.
To my understanding, I can do the cut with Nef_polyhedron_3::difference(). So
far so good.
Second, I'd like to identify the set of triangles in C which "came from B",
i.e. the set in intersect(C,B). How would I find these set?
Thanks.
- [cgal-discuss] Boolean operations on triangle surfaces, aviv.hurvitz, 12/27/2008
- Re: [cgal-discuss] Boolean operations on triangle surfaces, dekosser, 12/27/2008
- Re: [cgal-discuss] Boolean operations on triangle surfaces, Aviv Hurvitz, 12/28/2008
