cgal-discuss - Re: [cgal-discuss] Using minkowski_sum_2 to compute the Inner Fit
  • To:
  • Subject: Re: [cgal-discuss] Using minkowski_sum_2 to compute the Inner Fit
  • Date: Tue, 20 Jan 2009 09:22:55 +0200
Quoting "Alfredo Olivera"
Hello.
Given a Polygon representing the border of a region and a Polygon representing a piece that must be placed inside the region, I need to calculate the Inner Fit Polygon. This is, a polygon representing all the possible positions of the piece that totally overlap with the border.
Is there a direct way to calculate the Inner Fit Polygon using the minkowski_sum_2 procedure?
I think this is the only way you can do it. If you decompose it, you might as well decompose it already into convex pieces. The overall performance might be better.
One way to do it is to consider the complement of the polygon that represents the border, and decompose it into finite polygons that are accepted as summands of the Minkowski sum operation.
That's how I do it today, but it requires 2 calls (in my case) to the mink sum function. I wondered if there was a more efficient way... because I calculate hundreds of such polygons.
Thanks
Alfredo
