- To:
- Subject: [cgal-discuss] problem with xcode ...
- Date: Wed, 21 Jan 2009 00:31:30 +0100 (CET)
Hi i downloaded cgal but it think itdoesn't work properly under xcode.. Am
new
in both cgal and xcode ....
When include a library no error is displayed but when i use any function of a
header file, errors are displayed saying that th symbol (for example
Random::Random ) is unknown .. Please try to help thx
here is a copy of the errors :
Line Location Tool:0: "CGAL::assertion_fail(char const*, char const*, int)",
referenced from:
Line Location Tool:0: "CGAL::assertion_fail(char const*, char const*, int,
char
const*)", referenced from:
Line Location Tool:0: "CGAL::INTERN_MP_FLOAT::compare(CGAL::MP_Float const&,
CGAL::MP_Float const&)", referenced from:
Line Location Tool:0: "CGAL::IO::mode", referenced from:
Line Location Tool:0: "CGAL::MP_Float::MP_Float(double)", referenced from:
Line Location Tool:0: "CGAL::operator*(CGAL::MP_Float const&, CGAL::MP_Float
Line Location Tool:0: "CGAL::operator+(CGAL::MP_Float const&, CGAL::MP_Float
Line Location Tool:0: "CGAL::operator-(CGAL::MP_Float const&, CGAL::MP_Float
Line Location Tool:0: "CGAL::postcondition_fail(char const*, char const*, int,
char const*)", referenced from:
Line Location Tool:0: "CGAL::precondition_fail(char const*, char const*,
int)",
referenced from:
Line Location Tool:0: "CGAL::precondition_fail(char const*, char const*, int,
Line Location Tool:0: "CGAL::Random::Random()", referenced from:
Line Location Tool:0: __ZN4CGAL2IO4modeE$non_lazy_ptr in main.o
Line Location Tool:0: bool
CGAL::CGALi::operator!=<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>, CGAL::Tfb<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,
CGAL::Tdsfb<CGAL::Tds2<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>, CGAL::Tvb<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,
CGAL::Tdsvb<void> > >,
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>,
false>(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false> const&, void
const*)in main.o
CGAL::operator==<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>,
CGAL::Triangulation_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >,
>::Infinite_tester>(CGAL::Filter_iterator<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > >::Infinite_tester> const&,
CGAL::Tdsfb<void> > > > >::Infinite_tester> const&)in main.o
CGAL::operator==<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsvb<CGAL::Tds2<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>::Infinite_tester>(CGAL::Filter_iterator<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::operator==<CGAL::Triangulation_ds_edge_iterator_2<CGAL::Tds2<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > >,
>::Infinite_tester>(CGAL::Filter_iterator<CGAL::Triangulation_ds_edge_iterator_2<CGAL::Tds2<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Alpha_shape_2<CGAL::Delaunay_triangulation_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > >::initialize_interval_edge_map()in main.o
CGAL::Tdsfb<void> > > > > >::number_of_solid_components(double const&) constin
main.o
>::traverse(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Unique_hash_map<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>, bool,
CGAL::Handle_hash_function>&, double) constin main.o
CGAL::Tdsfb<void> > > > > >::update_alpha_shape_edges_list() constin main.o
CGAL::Default_allocator>::construct_insert<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false> const&)in
main.o
main.o
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>::increment()in
main.o
main.o
main.o
main.o
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>::clear()in main.o
CGAL::Default_allocator>::erase(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>)in main.o
CGAL::Default_allocator>::insert(CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > > const&)in main.o
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>::menion::menion(void*,
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>::Type)in main.o
CGAL::Default_allocator>::insert(CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
Line Location Tool:0: CGAL::Interval_nt<false>::Interval_nt(double, double)in
main.o
Line Location Tool:0: CGAL::MP_Float::MP_Float()in main.o
Line Location Tool:0: CGAL::MP_Float::operator*=(CGAL::MP_Float const&)in
main.o
Line Location Tool:0: CGAL::MP_Float::sign() constin main.o
CGAL::Multiscale_sort<CGAL::Hilbert_sort_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>::Multiscale_sort(CGAL::Hilbert_sort_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&, int, double)in main.o
CGAL::Quotient<CGAL::MP_Float>::operator+=(CGAL::Quotient<CGAL::MP_Float>
const&)in main.o
const&)in main.o
const&)in main.o
CGAL::Quotient<CGAL::MP_Float>::operator-=(CGAL::Quotient<CGAL::MP_Float>
const&)in main.o
const&)in main.o
const&)in main.o
Line Location Tool:0: CGAL::Real_embeddable_traits<CGAL::MP_Float,
CGAL::Boolean_tag<false> >::Compare::operator()(CGAL::MP_Float const&,
CGAL::MP_Float const&) constin main.o
Line Location Tool:0: CGAL::Sign
CGAL::quotient_cmp<CGAL::MP_Float>(CGAL::Quotient<CGAL::MP_Float> const&,
CGAL::Quotient<CGAL::MP_Float> const&)in main.o
Line Location Tool:0: CGAL::Split_double<CGAL::MP_Float>::operator()(double,
CGAL::MP_Float&, CGAL::MP_Float&) constin main.o
>::flip(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>, int)in main.o
>::insert_dim_up(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>, bool)in
main.o
CGAL::Tdsfb<void> > > >::insert_first()in main.o
>::insert_in_edge(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
>::insert_in_face(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > >::insert_second()in main.o
>::mirror_index(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>, int) constin
main.o
>::mirror_vertex(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
main.o
>::index(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>) constin
main.o
>::index(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
main.o
CGAL::Tdsfb<void> > > > >::neighbor(int) constin main.o
CGAL::Tdsfb<void> > > > >::set_neighbor(int,
CGAL::Tdsfb<void> > > > >::set_vertex(int,
CGAL::Tdsfb<void> > > > >::vertex(int) constin main.o
>::bounded_side(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&, CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > >::finite_vertex() constin main.o
>::insert(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >
> const&,
CGAL::Tdsfb<void> > > > >::Locate_type,
>::insert_first(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&)in main.o
>::insert_in_face(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&,
>::insert_outside_affine_hull(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&)in main.o
> > const&)in main.o
>::insert_outside_convex_hull(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&,
>::insert_outside_convex_hull_1(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&,
> > const&,
>::insert_outside_convex_hull_2(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&,
> > const&,
>::insert_second(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&)in main.o
>::march_locate_1D(CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
> > const&,
CGAL::Tdsfb<void> > > > >::Locate_type&, int&) constin main.o
>::march_locate_2D(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > const&,
>::oriented_side(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Point_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> > > const&)
constin main.o
>::segment(std::pair<CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_face_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > > > >, CGAL::Default_allocator>, false>, int> const&)
constin main.o
>::Triangulation_2(CGAL::Filtered_kernel<CGAL::Simple_cartesian<double> >
const&)in main.o
Line Location Tool:0: CGAL::Triangulation_cw_ccw_2::ccw(int) in main.o
Line Location Tool:0: CGAL::Triangulation_cw_ccw_2::cw(int) in main.o
CGAL::Tdsfb<void> > > > >::increment()in main.o
CGAL::Triangulation_ds_face_circulator_2<CGAL::Tds2<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
CGAL::Tdsfb<void> > > > >::operator++()in main.o
CGAL::Tdsfb<void> > > > >::operator++(int)in main.o
CGAL::Tdsfb<void> > > > >::operator--()in main.o
CGAL::Tdsfb<void> > > > >::operator--(int)in main.o
CGAL::Tdsfb<void> > > > >::operator->() constin main.o
>::Triangulation_ds_face_circulator_2(CGAL::CGALi::CC_iterator<CGAL::Compact_container<CGAL::Alpha_shape_vertex_base_2<CGAL::Filtered_kernel<CGAL::Simple_cartesian<double>
Line Location Tool:0: collect2: ld returned 1 exit status
Line Location Tool:0: symbol(s) not found
Line Location Tool:0: void CGAL::circumcenter_translateC2<double>(double
const&, double const&, double const&, double const&, double&, double&)in
main.o
- [cgal-discuss] problem with xcode ..., nabilthebad, 01/21/2009
- Re: [cgal-discuss] problem with xcode ..., Joachim Reichel, 01/21/2009
- Re: Re: [cgal-discuss] problem with xcode ..., nabilthebad, 01/21/2009
- Re: Re: Re: [cgal-discuss] problem with xcode ..., nabilthebad, 01/21/2009
- Re: [cgal-discuss] problem with xcode ..., Joachim Reichel, 01/22/2009
- Re: [cgal-discuss] problem with xcode ..., nikhil navkar, 01/23/2009
