- To:
- Subject: Re: [cgal-discuss] Approximation of a 2D polygon
- Date: Fri, 23 Jan 2009 10:22:54 -0200
Hello Alfredo,
Hello.We will.. there is work in progress for *precisely* this (specifically the variant where the simplified polygon contains a subset of the vertices of the original).
Given a 2D polygon, I need to determine a new polygon which is very similar to it but has much less vertices.
This is part of a pre-processing step of an optimisation algorithm in which I receive a polygon with ~2,000 vertices (which make any optimisation unusable) and I want to simplify it to ~100 vertices.
I do not have a quality measure to determine which approximation is better, so I am open in this sense. The data I have is such that an approximation is feasible (I have done it by hand, achieving good results).
There are two flavours of the problem:
1) The new polygon must be totally contained in the original polygon
2) The new polygon must totally contain the original polygon
Do we have any CGAL package that may help me on this?
Best
Fernando Cacciola
www.geometryfactory.com
- [cgal-discuss] Approximation of a 2D polygon, Alfredo Olivera, 01/22/2009
- Re: [cgal-discuss] Approximation of a 2D polygon, Fernando Cacciola, 01/23/2009
- Re: [cgal-discuss] Approximation of a 2D polygon, Alfredo Olivera, 01/23/2009
- Re: [cgal-discuss] Approximation of a 2D polygon, dekosser, 01/23/2009
