- To:
- Subject: Re: Re: [cgal-discuss] Progressive Mesh
- Date: Sun, 25 Jan 2009 19:17:28 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=CGA9fp0gqMPSfwkDol+d1c+nGK6rMMs5GaYDsvnR4UDSdEfVVVswSs7ljJy7GvB219 imrHjFVqzoaPH5VpOrvC5Gs4YEBUNVK9jpkBTP2amzPMX7Vd9P/Ny1AsQtfKWr2MwMhd cbSvwoQCKzuCjxvsrER1jQ18htQS33haPCVtA=
Ok, so I come back with another suggestion.
I had a look on the link you gave me and looked at the movies.
It is actually a behaviour of ParaView which you may know (open source software base on VTK for scientific data visualization):
http://www.paraview.org/
I indeed noticed that when I was making a 3D mesh rotate, such simplifications were carried out (most probably to decrease the CPU load).
As this software is based on VTK, I simply typped in Google: "vtk progressive mesh", and I found many results.
You should tried.
I most notably found this paper (Mesh Decimation Using VTK) which describe the classes in VTK allowing mesh decimation:
http://www.cg.tuwien.ac.at/courses/Seminar/SS2002/Knapp_paper.pdf
If you want to have a close look on these classes, I would recommend going to the doxygen documentation:
http://www.vtk.org/doc/nightly/html/classes.html
Regards,
Pierre
2009/1/24 <>
Pierre,
Thanks for the suggestion, but this is not really what I mean by the term
progressive mesh. Rather, what I meant was the progressive mesh structure
introduced by Hoppe
(http://research.microsoft.com/en-us/um/people/hoppe/proj/pm). Basically, the
reason I asked on the CGAL discuss list is because it seems like CGAL takes on
part of the way to implementing this structure. Namely, they provide the
EdgeCollapsable mesh concept. I was just curious how difficult it would be to
implement and properly keep track of the edge collapses and to reintroduce
removed vertices with a vertex split. I also wanted to see if anyone else had
done this, as I see no real use in re-inventing the wheel.
Thanks,
Rob
- [cgal-discuss] Progressive Mesh, rob.patro, 01/22/2009
- Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/23/2009
- Re: Re: [cgal-discuss] Progressive Mesh, rob.patro, 01/24/2009
- [cgal-discuss] Polyhedron demo problem, Rob, 01/24/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/25/2009
- Re: [cgal-discuss] Polyhedron demo problem, Laurent Rineau (GeometryFactory), 01/26/2009
- Re: [cgal-discuss] Polyhedron demo problem, Rob, 01/26/2009
- Re: Re: [cgal-discuss] Progressive Mesh, Pierre JUILLARD, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Andreas Fabri, 01/25/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/26/2009
- Re: [cgal-discuss] Progressive Mesh, Rob, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/27/2009
- Re: [cgal-discuss] Progressive Mesh, Fernando Cacciola, 01/28/2009
- Re: [cgal-discuss] Progressive Mesh, Rob Patro, 01/28/2009
