- To:
- Subject: [cgal-discuss] Geomview is giving exception for Convex Hull code
- Date: Mon, 26 Jan 2009 09:06:07 +0100 (CET)
Hi All,
I was running an example provided in cgal for incremental convex hull
algorithm, which uses geomview to display. When i run the code, I get
following
error:
fire_buffer: DRM_VIA_PCICMD returned -22.
write problem in the pipe while sending data to geomview.
Please provide solution if any exists for it.
Thanks
Avanindra
- [cgal-discuss] Geomview is giving exception for Convex Hull code, avanindra.singh, 01/26/2009
- Re: [cgal-discuss] Geomview is giving exception for Convex Hull code, Laurent Rineau (GeometryFactory), 01/26/2009
