- To:
- Subject: Re: [cgal-discuss] straight skeleton question
- Date: Wed, 28 Jan 2009 01:41:28 +0200
Do you want a full gable? (that means, that an entire side is vertical, and
not
only part of it). You can compute a weighted straight skeleton in which the
gable has a very small speed, but CGAL does not support weighted straight
skeletons. I can send you some code for it, if you like.
Amir.
Quoting Dylan Cannon
> I hope this isn't an obvious question - I couldn't find it in the archives.
> I'm trying to use the straight skeleton algorithm in cgal to generate
> roofing profiles. It works great for hip roofs, but for a mixed hip-gable
> roof I'm not sure if there is an easy way to force the algorithm to make one
> of the roofing planes with infinite slope. Can anyone offer an easy solution
> to this? - Thanks!
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] straight skeleton question, Dylan Cannon, 01/28/2009
- Re: [cgal-discuss] straight skeleton question, avaxman, 01/28/2009
- Re: [cgal-discuss] straight skeleton question, Dylan Cannon, 01/28/2009
