- To: , Bernd Gaertner <>
- Subject: Re: [cgal-discuss] Reverse of Convex hull?
- Date: Wed, 11 Feb 2009 17:16:39 +0100
Hanjun Kim wrote:
Hi all,
Given a set of points in R^n, cgal finds a convex hull of it, i.e. vertices of
the the hull.
But can cgal do some sort of the converse?, i.e. given vertices( may assume
lattice points) of of a convex hull, can it find all lattice points in the
hull? I looked it up, but it doesn't seem so.
No, CGAL cannot do this directly. What you want is called the integer hull of a set of points, and there are general techniques from discrete geometry and combinatorial optimization that address this. In a nutshell, the complexity of the known algorithms grows exponentially with the dimension n. Knowing this, the following brute-force approach can almost be considered as efficient: go through all the lattice points in the bounding box of the input, and for each one check whether it is contained in the convex hull. The latter can in fact be done without computing the convex hull, by linear proramming (see http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/QP_solver/Chapter_main.html#sec:QP-iterators on how to do this with CGAL).
Best,
Bernd.
- [cgal-discuss] Reverse of Convex hull?, Hanjun Kim, 02/11/2009
- Re: [cgal-discuss] Reverse of Convex hull?, Bernd Gaertner, 02/11/2009
