cgal-discuss - Re: [cgal-discuss] Concave Polygon's
  • To:
  • Subject: Re: [cgal-discuss] Concave Polygon's
  • Date: Sat, 14 Feb 2009 13:39:16 +0100
Hi,
I am studing the part XIII of CGAL documentation, in specific the Chapter 49 "Inscribed Areas".
What I need is to find the maximum area inscribed in the polygon, but the "Concave Polygon" and the Functions presents in library do only wich Convex Polygon.
I doubt that what you want is there in a ready-to-use fashion, but it would be easier to tell, if you could describe your problem more precisely. So you have a simple polygon with n vertices in R^2 and you want the maximum area ... among ...?
For instance, should the vertices of the maximum area ... be vertices of the input polygon or just arbitrary points along the boundary?
/Michael
