cgal-discuss - Re: [cgal-discuss] (centroidal) voronoi tasselation
  • To:
  • Subject: Re: [cgal-discuss] (centroidal) voronoi tasselation
  • Date: Thu, 19 Feb 2009 17:02:52 +0100
The Voronoi diagram is the dual of the Delaunay triangulation.
For instance, the dual of a Delaunay tetrahedron is a Voronoi vertex.
Szymon Stoma wrote:
maybe my question is trivial, but.. from what i understand Delaunay triangulations work on triangles/tetrahedron. My question is about compartments described by polygons/polyhedron. can it be easly performed using the CGAL? thanks and sorry if i am asking about sth. obvious.
2009/2/19 Monique Teillaud < <mailto:>>
Hi Szymon,
CGAL provides computation of Delaunay triangulations in both 2D and 3D.
you can have a look at the package overview
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/packages.html#part_VIII
The Delaunay triangulation classes offer some dual functions to
compute features of the Voronoi diagram. This is described in the
manual of the corresponding classes.
Best regards,
Monique Teillaud
Szymon Stoma wrote:
hello,
i have a general question. i would like to discretize the
continous, convex subset S of r2/r3 into smaller compartments
(such as their intersection is empty, and sum is equal to S).
since i would like to have some influence on the comparments, i
am preparing the editor allowing for manual manipulation of the
compartments. to make the editing easier (especially in 3D) i
would like to use a cloud of points representing implicitely the
compartments. to get the exact geometry of each compartment i
would like to use voronoi concept. i hope i am clear at this point.
1. will i find routines allowing me to calculate the edges (and
their geometry) of each compartment in 2D in CGAL library?
2. will i find routines allowing me to calculate the faces (and
their geometry) of each compartment in 3D in CGAL library?
3. what other library might be good for this task (it should be
something i could use from C/C++/Python).
thank you very much for any answer and suggestion.
cheers,
szymon stoma.
-- You are currently subscribed to cgal-discuss.
