- To:
- Subject: Re: [cgal-discuss] Re: conversion between Gmpq and double
- Date: Fri, 20 Feb 2009 14:15:46 +0100
On Friday 20 February 2009 14:03:46 Jean Pierre Charalambos wrote:
> Hi!
> any thought regarding my conversion issue? I have been not able to fix it
Nobody seems able to answer you right now. Can you post a small and complete
C++ example that shows your problem? That might help.
Remember those intructions: http://www.cgal.org/bug_report.html
Those indications are general guidelines to follow, if you want to maximize
your chances to get an helpful answer.
Laurent Rineau, PhD
Engineer at GeometryFactory
http://www.geometryfactory.com/
- [cgal-discuss] conversion between Gmpq and double, Jean Pierre Charalambos, 02/18/2009
- [cgal-discuss] Re: conversion between Gmpq and double, Jean Pierre Charalambos, 02/20/2009
- Re: [cgal-discuss] Re: conversion between Gmpq and double, Laurent Rineau (GeometryFactory), 02/20/2009
- Re: [cgal-discuss] Re: conversion between Gmpq and double, Sebastien Loriot, 02/20/2009
- Re: [cgal-discuss] Re: conversion between Gmpq and double, Jean Pierre Charalambos, 02/21/2009
