- To: <>
- Subject: [cgal-discuss] Arr_vertical_decomposition_2.h
- Date: Fri, 20 Feb 2009 16:16:28 +0100
Hi,
there is a bug in Arr_vertical_decomposition_2.h
from CGAL 3.4 in the following code snippet (line 85):
// Go over all isolated vertices and
collect their points. To each point
// we attach its vertex handle.
std::vector<Vd_point_2> iso_pts_vec
(arr.number_of_isolated_vertices());
Vertex_const_iterator vit;
Vertex_const_handle iso_v;
i = 0;
for (vit = arr.vertices_begin(); vit !=
arr.vertices_end(); ++vit, ++i)
// Associate isolated point with the vertex that
represents it.
if (vit->is_isolated())
iso_v = vit;
iso_pts_vec[i] = Vd_point_2 (vit->point(),
iso_v);
The "++i" should be moved to the end
of the if-clause. Otherwise i goes up to
arr.number_of_vertices() while the vector iso_pts_vec is initialized
for arr.number_of_isolated_vertices() elements.
Kind regards,
Jannis Warnat
- [cgal-discuss] Arr_vertical_decomposition_2.h, Jannis Warnat, 02/20/2009
- Re: [cgal-discuss] Arr_vertical_decomposition_2.h, Efraim Fogel, 02/23/2009
