[cgal-discuss] using CGAL::squared_radius to calculate circumradius of triangle
- To:
- Subject: [cgal-discuss] using CGAL::squared_radius to calculate circumradius of triangle
- Date: Sat, 21 Feb 2009 01:40:34 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.hk; h=Message-ID:Received:X-Mailer:Date:From:Reply-To:Subject:To:MIME-Version:Content-Type; b=HU7jPeKgQgg6gqG44V00C72FbWvvvzaojZl9hVuoHj9fwttBEZIMpkY6mjTcCnBvwVUWa5xSzHIL83mOsCzlcEys9mWC9YoAPantPL7aHD2LjJm1V9xq/KqCrfw4fgMrvrQWt6fn37dimCNFcZug6zt0FAmbz7lrPkZkx+Dqyt0=;
Hi. I have been trying to calculate the circumradius of every triangle inside a 3D triagulation. I am using Visual Studio C++ 2005, CGAL3.3.1 with boost C++ library 1.35.0 And I have 1.00GB RAM in my PC. Currently, I attempted to access the triangles of the triangulation through the Finite_facets_iterator provided in CGAL in the following way. void check_circumradius(list<Finite_facets_iterator>& selected_facet) { double fifth_nearest_1; double fifth_nearest_2; double fifth_nearest_3; double max_fifth_nearest; double circumradius = 0; Finite_facets_iterator start = Dt.finite_facets_begin(); Finite_facets_iterator end = Dt.finite_facets_end(); Finite_facets_iterator curr; Vertex_handle v1; Vertex_handle v2; Vertex_handle v3; Triangle triangle; for(curr = start; curr != end; ++curr) { triangle = Dt.triangle(*curr); cout << ++i << "check circumradius" << endl; v1 = curr -> first -> vertex(0); v2 = curr -> first -> vertex(1); v3 = curr -> first -> vertex(3); fifth_nearest_1 = (v1 -> fifth_nearest_dist) * 3; fifth_nearest_2 = (v2 -> fifth_nearest_dist) * 3; fifth_nearest_3 = (v3 -> fifth_nearest_dist) * 3; max_fifth_nearest = max_of_three(fifth_nearest_1, fifth_nearest_2, fifth_nearest_3); circumradius = CGAL::sqrt(squared_radius(triangle.vertex(0), triangle.vertex(1), triangle.vertex(2))); if (max_fifth_nearest >= circumradius) { selected_facet.push_back(curr); } } } By using t.number_of_facets(), I found out that there are more than 4000000 facets to process. And in my current code, I need approximately 1 hour 6 minutes to process all of the facets. May I ask if this running time is normal in CGAL? Is it I have misused the features of CGAL in some way? Thank you for your help. |
Yahoo!香港提供網上安全攻略,教你如何防範黑客!了解更多
- [cgal-discuss] using CGAL::squared_radius to calculate circumradius of triangle, Query Cgal, 02/21/2009
- Re: [cgal-discuss] using CGAL::squared_radius to calculate, Ariel Baez, 02/22/2009
- Re: [cgal-discuss] using CGAL::squared_radius to calculate, Query Cgal, 02/22/2009
