- To:
- Subject: Re: [cgal-discuss] member "first" of a facet iterator
- Date: Mon, 23 Feb 2009 11:22:41 +0100
Hi,
it is not a member of the facet iterator but rather of the facet: As you
can find in the manual a facet is represented as
std::pair<Cell_handle,int>:
http://www.cgal.org/Manual/3.4/doc_html/cgal_manual/TriangulationDS_3/Chapter_main.html#TDS3-sec-intro
This should make it clear.
best
Manuel
Query Cgal wrote:
> Hi.
> When I am using a facet iterator of a triangulation, I found that there
> is a member called first which can be used in the following way.
> itr -> first -> vertex(0);
> where itr is a facet iterator of a triangulation
> It seems that it returns a vertex of a triangular face. But I am not
> sure if it is true.
> Therefore, I have tried to search the CGAL manual for that.
> However, I cannot find anything thing about the member "first" of the
> facet iterator.
> Actually, what is itr -> first?
> Is it anything that is supposed to be used by us ?
> Thank you
> Yahoo!香港提供網上安全攻略,教你如何防範黑客!*了解更多*
> <http://hk.promo.yahoo.com/security/>
- [cgal-discuss] member "first" of a facet iterator, Query Cgal, 02/22/2009
- Re: [cgal-discuss] member "first" of a facet iterator, Manuel Caroli, 02/23/2009
