cgal-discuss - Re: [cgal-discuss] Triangulation_cell_base_with_info_3 - how to access
  • To:
  • Subject: Re: [cgal-discuss] Triangulation_cell_base_with_info_3 - how to access
  • Date: Fri, 13 Mar 2009 19:51:29 +0100
Hi Qi !
a écrit :
Hi, I'm using Triangulation_cell_base_with_info_3 so that I can augment cells
with more information, but reading the manual, it says:
"It provides an easy way to add some user defined information in cells. Note
that input/output operators discard this additional information."
This statement confuses me, as if input/output iterators discard this
additional information, does that mean I cannot access the extra information
when I am using Triangulation_cell_base_with_info_3 with for example a
hierarchical delaunay triangulation (as below)?
for (Finite_cells_iteratorI fit=dti.finite_cells_begin();
fit!=dti.finite_cells_end();++fit)
cout<<(*fit).info.in_model<<endl; <------compile error here
Try info() with the parenthesis ?
Did you find the the manual or the example program confusing about this?
"input/output operators" in the manual refer to the file reading
and writing routines.
Sylvain Pion
INRIA Sophia-Antipolis
Geometrica Project-Team
CGAL, http://cgal.org/
