- To:
- Subject: [cgal-discuss] Questons on Polyhedron_3::inside_out ()
- Date: Tue, 17 Mar 2009 17:27:45 -0700
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=YEriM4yu3ZU5oD6GfLUFVwmmXlXUhGb1gCoNzsU0NmOHEeSXIZIie66rFjPHym2LvU zy9RmwLFiNOkeSvpWlBuM+Bv3pCvlgjhVinp8R+jmtZlGjyOa3irSlgN394QjA850Vfl CWM4VNB2o9u9IukcRNKbbeM/7Sb6gFo3l7oPw=
Hi,
I am trying to reverse the facets orientation of a polyhedron P by using a polyheron_3::inside_out (). P is verified to be valid. However, the program terminates abnormally. When I debug the code, I see it terminates when hitting the line "std::transform( planes_begin(), planes_end(), planes_begin(), opp);" in the code snippet from Polyhedron_3.h:
void inside_out_geometry( Tag_true) {
typename Traits::Construct_opposite_plane_3 opp
= traits().construct_opposite_plane_3_object();
My compiler is Visual Studio 2008 and I am using CGAL-3.4. Is there any settings I am missing or is it a bug?
Thanks.
Joe
- [cgal-discuss] Questons on Polyhedron_3::inside_out (), Joe C, 03/18/2009
