- To:
- Subject: Re: [cgal-discuss] Sorting Planes Lexicographically
- Date: Wed, 18 Mar 2009 17:26:19 +0200
One way to do it is creating a total order of the (unnormalized) normals, described below, then adding a sub order for the translation of the plane.
In general you need to maintain a lexicographic ordering on the polar coordinates u and v of the normals without explicitly computing and obtaining them.
Consider the unit sphere parameterized by two parameters u and v as follows: $\phi_S(u, v) = (\cos u \cos v, \sin u \cos v, \sin v)$, where $\Phi = [-\pi, \pi] \times [-\frac{\pi}{2}, \frac{\pi}{2}]$.
First, assume that the south pole (0,0,-1) is the smallest point of all points on the sphere, and the north pole (0,0,1) is the largest point. Let's call these 2 points contraction points. Secondly, assume that any point on the opposite Prime Meridian (with y = 0, and x < 0) is smaller than any point that is not on the opposite Prime Meridian (and, of course, smaller than the north pole.) Let's call the opposite Prime Meridian the identification arc.
Thirdly, you need a procedure that compares two points $p_1$ and $p_2$ by their $u$-coordinates that admits the assumption that the input points do not coincide with the contraction points and do not lie on the identification arc. Recall, that points are in fact unnormalized vectors in R^3. We project $p_1$ and $p_2$ onto the $xy$-plane to obtain two-dimensional unnormalized vectors $\hat{p_1}$ and $\hat{p_2}$, respectively. We compute the intersection between the identification arc and the $xy$-plane to obtain a third two-dimensional unnormalized vector $\hat{d}$. Finally, we test whether $\hat{d}$ is reached strictly before $\hat{p_2}$ is reached, while rotating counterclockwise starting at $\hat{p_1}$. This geometric operation is supported by every geometric kernel of \cgal{}.
Forthly, you need a procedure that compares two points $p_1$ and $p_2$ lexicographically. It first applies \the procedure above to compare the $u$-coordinates of the two points. If the $u$-coordinates are equal, it applies a predicate that compares the $v$-coordinates of two points with identical $u$-coordinates. This predicate first compares the sign of the $z$-coordinates of the two unnormalized input vectors. If they are identical, it compares the squares of their normalized $z$-coordinates, essentially avoiding the square-root operation.
Amir Vaxman wrote:
What I need is any total order on planes, as I have a set of planes, and--
want to know efficiently if another input plane is already in the set. The
planes in the set are not parameterized in any assumed fashion, and neither
does the input plane parameterized the same way as the plane in the set it
might fit to, so the only thing given is that the set planes are different.
New entities are no problem, but normalization is, because I use a gmpq
kernel.
Amir.
-----Original Message-----
From: Andreas Fabri [mailto:] Sent: Wednesday, March 18, 2009 2:14 PM
To:
Hi Amir,
Isn't the most important question, what do you want to achieve by orderng
them?
Take the vector which has the same direction as the normal.
That orders them also in the case they have the same normal.
Is the question if they can be ordered based on the a,b,c,d
without computing new entities ?
andreas
Amir Vaxman wrote:
Yes, but then you have to normalize.. (there is no Direction_3 total order like in Direction_2).
*Sent:* Wednesday, March 18, 2009 1:34 PM
*To:*
*Subject:* Re: [cgal-discuss] Sorting Planes Lexicographically
I am guessing that you could sort the normals to the planes (lexicographically).
On Mon, Mar 16, 2009 at 3:01 PM, Amir Vaxman < <mailto:>> wrote:
Hello,
Is there a way to sort planes lexicographically in CGAL, in a similar manner as points are sorted? Of course, I am looking for something invariant of plane parameterization.
Amir.
____ _ ____ _
/_____/_) o /__________ __ //
(____ ( ( ( (_/ (_/-(-'_(/
_/
- [cgal-discuss] Sorting Planes Lexicographically, Amir Vaxman, 03/16/2009
- Re: [cgal-discuss] Sorting Planes Lexicographically, Ophir Setter, 03/18/2009
- RE: [cgal-discuss] Sorting Planes Lexicographically, Amir Vaxman, 03/18/2009
- Re: [cgal-discuss] Sorting Planes Lexicographically, Andreas Fabri, 03/18/2009
- Re: [cgal-discuss] Sorting Planes Lexicographically, Efraim Fogel, 03/18/2009
- Re: [cgal-discuss] Sorting Planes Lexicographically, Peter Hachenberger, 03/18/2009
