- To:
- Subject: Re: [cgal-discuss] From vertex pointers to vertex handles?
- Date: Sun, 22 Mar 2009 21:22:02 +0100
Hi Tom,
I'm not sure I understand your problem well but I don't see a direct solution here. Why don't you work with pointers to Vertex_handles or directly with Vertex_handles?
Maybe it would be helpful if you could post some pieces of code to clarify.
Manuel
Tom Kazimiers wrote:
Hi,
like in the triangulation example "adding handles" I have my own data
structure as vertex for constrained 2D delaunay triangulations.
This works pretty good and I have only one problem: Most of the time I
deal with pointers to my vertices in the triangulation.
If I now want to call a method on the mesh like incident_vertices (
Vertex_handle v) I have to get a vertex_handle out of the pointer to the
vertex.
Is there a way to do this?
Thanks in advance,
Tom
- [cgal-discuss] From vertex pointers to vertex handles?, Tom Kazimiers, 03/22/2009
- Re: [cgal-discuss] From vertex pointers to vertex handles?, Manuel Caroli, 03/22/2009
- Re: [cgal-discuss] From vertex pointers to vertex handles?, Tom Kazimiers, 03/22/2009
- <Possible follow-up(s)>
- Re: [cgal-discuss] From vertex pointers to vertex handles?, Daniel Duque, 03/23/2009
- RE: [cgal-discuss] From vertex pointers to vertex handles?, Amir Vaxman, 03/23/2009
- Re: [cgal-discuss] From vertex pointers to vertex handles?, Benjamin schwarz, 03/23/2009
- Re: [cgal-discuss] From vertex pointers to vertex handles?, Tom Kazimiers, 03/23/2009
- Re: [cgal-discuss] From vertex pointers to vertex handles?, Sylvain Pion, 03/23/2009
