cgal-discuss - Re: [cgal-discuss] Reading and writing Point_3 values to file
  • To: <>
  • Subject: Re: [cgal-discuss] Reading and writing Point_3 values to file
  • Date: Thu, 26 Mar 2009 19:02:01 +0530
Hi
You can easily read or write points. You can user  Point_3 from kernel and using ofstream and ifstream you can read and write.
Here is example :
typedef kernel::Point_3 Point_3;
Reading :
int pointsize;
Point p;
std::ifstream outfile;
outfile.open ("test.pts");
outfile >> pointsize;
for(int i=0; i<pointsize; ++i)
    outfile >> p;
    // now you have point p that you can do what you want
Writing :
std::ofstream outfile;
outfile << Points.size() << "\n";
for (int i=0; i< Points.size(); ++i)
outfile << Points[i] << "\n";
All this is only sample psuecode. You have to implement your self
----- Original Message -----
To:
Sent: Thursday, March 26, 2009 3:04 PM
Subject: [cgal-discuss] Reading and writing Point_3 values to file
Hello,
Is there a convenient way to write Point_3 values to a file stream (using a cout operator), and then reading them, using a cin in the same order? I am using a gmpq kernel.
Amir.
