- To:
- Subject: Re: [cgal-discuss] Problems with OS X, GCC 4.2.1 and arrangement_2
- Date: Mon, 30 Mar 2009 14:29:03 -0400
Hi Sylvain,
Happens with -O0. Are there other things I should shut off to try to produce even more "basic" output? My original test had only -I to find CGAL and the full path to the CGAL static archives.
cheers
ben
Sylvain Pion wrote:
Ben Supnik a écrit :
Hi Y'all,
I've hit a case where I get assertion failures doing an insert_curves on the arrangement_2 class. (Exact numeric type, segment traits with history, CGAL 3.3.1.)
Here's the rub:
On Linux (GCC 4.2.4) my code runs properly.
On OS X (GCC 4.2.1 build 5566) my code hits a precondition violation.
Has anyone hit this before? Is anyone working with CGAL on a known good Mac compiler?
I am building GCC 4.3.3 now to try that...
Do compiler optimization options make a difference?
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Problems with OS X, GCC 4.2.1 and arrangement_2, Ben Supnik, 03/30/2009
- Re: [cgal-discuss] Problems with OS X, GCC 4.2.1 and arrangement_2, Sylvain Pion, 03/30/2009
- Re: [cgal-discuss] Problems with OS X, GCC 4.2.1 and arrangement_2, Ben Supnik, 03/30/2009
- Re: [cgal-discuss] Problems with OS X, GCC 4.2.1 and arrangement_2, Laurent Rineau (GeometryFactory), 03/30/2009
