- To: <>
- Subject: Re: [cgal-discuss] Using Spatial Search (Kd-tree) to find segment-mesh
- Date: Tue, 31 Mar 2009 13:33:28 +0530
Hi Pierre
Where is exactly demo located ? I tried to find it . Is it in example directory or demo directory ?
----- Original Message ----- From: "Pierre Alliez" <>
To:
Sent: Tuesday, March 31, 2009 12:48 PM
hi Edson,
from our experience an AABB tree a la OPCODE is even faster.
from CGAL-3.4 you can already experiment the surface remeshing demo in the Polyhedron demo - which uses the undocumented AAABB tree data structure. we can achieve ~100K queries per sec on a 100K triangle surface mesh.
please let us know how it goes in your application - as we are preparing a documented component for one future release.
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
Edson Tadeu a écrit :
Can CGAL Kd-tree (Spatial Search) be used to find the intersection between a line segment (or ray) and a mesh composed of 3D triangles?--
Like in: http://www.cs.uoi.gr/~fudos/grad-exer1/doc/a00045.html <http://www.cs.uoi.gr/%7Efudos/grad-exer1/doc/a00045.html> (asr::KDTree::intersect)
Thanks,
Edson
- [cgal-discuss] Using Spatial Search (Kd-tree) to find segment-mesh intersection, Edson Tadeu, 03/30/2009
- Re: [cgal-discuss] Using Spatial Search (Kd-tree) to find segment-mesh, Pierre Alliez, 03/31/2009
- Re: [cgal-discuss] Using Spatial Search (Kd-tree) to find segment-mesh, naresh, 03/31/2009
- Re: [cgal-discuss] Using Spatial Search (Kd-tree) to find segment-mesh, Laurent Rineau (GeometryFactory), 03/31/2009
