cgal-discuss - Re: [cgal-discuss] largest axis-parallel rectangle inside convex
  • To: ,
  • Subject: Re: [cgal-discuss] largest axis-parallel rectangle inside convex
  • Date: Tue, 31 Mar 2009 16:01:25 +0200 (CEST)
Hi Stefan,
> The documentation in Chapter 55 (Inscribed Areas) states: "We
> further provide an algorithm for computing the maximal area
> inscribed axis parallel rectangle."
> I just can't find any such function. Where is it to be found?
the following paragraph states it. It's not a function, though, it is
implemented as a data structure called
CGAL::Largest_empty_iso_rectangle_2<T>.
The smallest enclosing rectangle, otoh, can be found using
CGAL::min_rectangle_2, cf. Section 52 on Bounding Volumes.
hth,
Michael
