- To:
- Subject: Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss]
- Date: Tue, 31 Mar 2009 19:36:03 +0200
Hi,
> I am trying to compile the Polyhedron demo, but after running cmake I
> get this messages:
> -- A library with LAPACK API not found. Please specify library location.
> -- TAUCS requires LAPACK and BLAS.
> -- NOTICE: This demo requires QGLViewer, and will not be compiled.
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /home/ale/src/mesh/cgal/demo/Polyhedron
> But I have QGLViewer, in fact two versions of it (for qt3 and qt4),
> dpkg -l |grep libqglviewer
> libqglviewer-qt3-2 2.3.1-3
> libqglviewer-qt3-dev 2.3.1-3
> libqglviewer-qt4-2 2.3.1-3
> libqglviewer-qt4-dev 2.3.1-3
> Any hint?
First of all, you also need LAPACK / BLAS. You can simply install
liblapack-dev and libatlas-base-dev (listed as Suggests: dependency of
libcgal-demo).
Then you need TAUCS, which is unfortunately not available as Debian package.
I don't know why QGLViewer isn't found.
Joachim
- Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Alejandro Aguilar Sierra, 03/31/2009
- Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Laurent Rineau (GeometryFactory), 03/31/2009
- Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Joachim Reichel, 03/31/2009
