- To: <>
- Subject: Re: [cgal-discuss] GhostNet
- Date: Wed, 1 Apr 2009 13:27:50 +0530
You are the BIG JOKE .
----- Original Message -----
To:
Sent: Wednesday, April 01, 2009 12:32
PM
Subject: [cgal-discuss] GhostNet
Dear CGAL users,
it seems that the GhostNet spying
operation, http://en.wikipedia.org/wiki/Ghostnet
, discovered by the Munk Center for International Studies at
the University of Toronto, mainly infiltrated machines through the trojan
horses of Open Source Software projects.
Our organization (DST)
downloaded and analyzed several software packages, where French research
labs like INRIA are implied, and we discovered that among several other
projects the CGAL project was chosen as a vector of infection, probably
due to its worldwide users.
The file CGAL/basic.h contains some
"invisible" code, which, when compiled, every time an application
that includes the header file is executed, sends sensible information
about the environment of the running application via UDP broadcasts (in
order not to reveal a fixed destination IP address).
Malgre the
source code distribution, not even the developers were aware of it (Last
night we interrogated several developers at Inria and GeometryFactory). The
reason is simple: CGAL/basic.h is not just plain ascii but encoded in
UTF-EBDIC, which makes that the subtext is not displayed in development
environnements like emacs, vim, DeveloperStudio ou Eclipse. In fact, we
discovered it when we loaded the header file in the text editor of
DerriereLaLune, the French fork of Eclipse.
We *urge* you to
replace CGAL-3.4/include/CGAL/basic.h with the attached clean version in
order to avoid further problems with
GhostNet.
Cordialement,
Maurice Oustache http://www.linkedin.com/in/mauriceoustache
