- To:
- Subject: Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss]
- Date: Wed, 1 Apr 2009 10:00:23 -0600
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type:content-transfer-encoding; b=t6BlYBbKlc6R4JXbG53hP4J82EvNMw7cT7zxE32j26qxfyQ3dp4Z4icddR9MH79ZZd 63TcLoqIryMkkZm157/JM678ZHfibv2LRFKG/VHY7IFyJRj3PIGCWm/3lnZ3pPI8Nnu8 b0GCF//I+jZsCasdP99j8I43aJ+dRjFTf9q6M=
Hi,
I did the trick you told me (and I also installed lapack and atlas).
It compiles now, thank you very much. But it doesn't link. Still
problems with Qt locations. I'll try to make it tonight.
Thanks again and regards,
-- A.
On Tue, Mar 31, 2009 at 12:11 PM, Laurent Rineau (GeometryFactory)
wrote:
> On Tuesday 31 March 2009 19:36:03 Joachim Reichel wrote:
>> First of all, you also need LAPACK / BLAS. You can simply install
>> liblapack-dev and libatlas-base-dev (listed as Suggests: dependency of
>> libcgal-demo).
>> Then you need TAUCS, which is unfortunately not available as Debian
>> package.
> Those packages are not mandatory to compile the polyhedron demo. If they are
> missing, some features will be also missing, but most of the demo does not
> require them.
> Laurent Rineau, PhD
> Engineer at GeometryFactory
> http://www.geometryfactory.com/
- Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Alejandro Aguilar Sierra, 04/01/2009
- Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Laurent Rineau (GeometryFactory), 04/02/2009
- Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Joachim Reichel, 04/02/2009
- Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Alejandro Aguilar Sierra, 04/03/2009
- Re: Compiling the Polyhedron demo on Debian GNU/Linux Re: [cgal-discuss], Laurent Rineau (GeometryFactory), 04/03/2009
