- To:
- Subject: [cgal-discuss] Behavior of merging opp-direction curves - arrangement_2
- Date: Wed, 01 Apr 2009 13:38:32 -0400
Hi Y'all,
I am trying to figure out how opposite-direction, identical-supporting-line curves are merged with the arrangement_2 package.
- If I insert a curve and at least part of the curve is "on top of" (but opposite direction) an existing curve, what happens? (I _think_ in this case the newly inserted curve is _not_ inserted for this section.
- If I merge two maps that contain opposite direction, overlapping curves, which "direction" is chosen to make the new sub-curve representing the overlapping region?
(This is the case that I have no idea about...I looked through sweep_line_2 and the overlay visitor, and it appears that the choice of which direction to take is deterministic, but the sweep code makes my head hurt.)
cheers
ben
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] Behavior of merging opp-direction curves - arrangement_2, Ben Supnik, 04/01/2009
- Re: [cgal-discuss] Behavior of merging opp-direction curves -, Ophir Setter, 04/02/2009
